Home theater hook up | SatelliteGuys.US
BruceE
80
I am working on a home theater setup and I have a problem. I have connected my VIP722 to my receiver by HDMI cables. My problem is how do I get my signal back on the tv in my bedroom?
Thanks for any info on this problem.
BruceE
BruceE
That really isn't enough information for us to help you. Is this bedroom TV in addition to the set being fed by the receiver? Do you want to receive different programming?
The 722 can only output HD on TV1. If you are willing to watch the same thing on the bedroom TV that is showing on the main one, you can hook up the bedroom TV via component outputs and analog/toslink.
If yiou need independent TV2 output, you will be forced to use SD TV2 outputs and won't receive a HD signal on the second set.
Ordered a Vudu box from Bestbuy
Plez help..about WD TV!
