HIC/WAP/ WJ...no internet connection | SatelliteGuys.US
  • Thread starter Thread starter KAB
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
KAB
22,334
6,340
Fishers, IN
Background: Initial install had WAP connected to Hopper via ethernet. Distance from it to WJ was too far for consistent connection. The long room in which I have WJ has a coax at the opposite end of the room. I hooked that cable to a client port of the node and ran to a HIC, then connected to WAP. Signal is strong and no problems with them seeing each other.
The one problem since the re-hook up, is that WJ does not detect internet. Moca details in Diagnostics/Network show the HIC is NOT MOCA linked. Bridging IS enabled at hopper. I can find no way configure linking. Is this situation a trade-off for WAP not being connected directly to Hopper? Pass through port on HIC is not tapped. Should it be?
Netflix Intermittant On H3
tuner rebooting every ~20 minutes or so
