HH100 Motor Problem! | SatelliteGuys.US
tup14
2
I was taking the cable off my HH100 Motor(it is a T.V. Dish motor) and it started to move internally, I put a common screwdriver inside the receptacle to hold nut so I could take coax fitting off. Well it would not work after this so took it apart and as you see from picture below it broke the fitting inside. I heard it is a pc mount" F-61 connector but checked and it is incorrect! Below is a picture of it if you have it could you let me know? Thanks Doug
most have a Mfg Warrantee
if you ordered it from one of the gold sponsors you might e-mail and ask them
I've always found them to be helpfull
please help
pan 2700 remote
