Help with message: "set current time for timer recording or reminder "?? | SatelliteGuys.US
RWB
41
Each time the 722 turns on in the morning I get this message "set current time for timer recording or reminder". I have no manual timers setup and I can't find any other timer issues.
Anyone know what this means?
Thanks,
722 as nothing else is connected. If it was the TV then it would show up when the set is turned on.
The message is displayed for a few seconds while the Dish screensaver is on (before you press select).
Where is the CW HD?
HD Only Pak?
