Help with HR20 | SatelliteGuys.US
Help with HR20
Alvarez
364
Brownsburg, IN
I have a few questions that I can't figure out... I have tinkered some but can't get it and you guys might be able to answer it right away and help me out.
On my old Tivo I could click the >| button twice and it would take me to the end and then the beginning right away... this button is on the HR20 remote but it skips 30 secs I believe. Is there a way to goto the end and beginning of a recorded show quickly?
afaik rew and ff only way to jump from begining to end on hr20 as of now
maybe theyll put that feature in a software update in the future
You can do the "skip to tick" by holding FFW down for 3 seconds and it will jump to the next tick. Not as smooth but works. I don't think there is anyway to just jump to the end or beginning but then I don't mess with the trick play stuff much. On DBSTalk there is a very large "Tips and Tricks FAQ" as well as a "Tivo to HR20 Survival Guide" that might help you out with these things.
Go to the HR20 forum there and then to the HR20 resrouces subforum.
Slimline Alignment Problem
