Help with EPG | SatelliteGuys.US
Help with EPG
rdel
326
Hi Everybody
I'm trying to make a EPG guide for the g10r stations, I've tried channelmaster and the fortec setup but I can't seem to find a way to enter the names into the hour time slots. Has anyone had any luck doing this? :confused:
( I can't even access the hour and half hour time slots)
Thanks Guys
rdel
fortec classic na
Not quite sure what you are up to or mean, but the EPG guide in the Fortec, or any other receiver for that matter, is a moot point, because the programmers, in this part of the world, don't put any information there to look at or use. I think D* and E* may put info there, but that's moot too, because they are scrambled. If you want to use the EPG on your Fortec, I'm afraid you're going to have to move to Europe. Sorry.......
Al
I want to list the shows on all the channels on g10r so I can hit the the EPG button and scroll across to see whats comming on. I'm not sure but I thing it can be used to set the timer. If it can't then you will have to set the timer manually. (It would be helpfull with the PVR units).
I allready have dishnetwork and the only thing I find of interest is SG1 and Atlantis.
I would rather have the old shows from RTN ( I guess I'm old. lol ):)
rdel
the EPG doesn't work in this country for 99% of the stations. The only way to find out about programming info is to customize a list at www.titantv.com
you can add all the G10 channels (well most of them) and have an easy to read list :)
see attached screenshots. Some of the channels are not on G10 but you get the jist
I've got titantv and I really like it (very nice setup). I'm thinking about getting a dreambox, I know it's an open source unix operating system and before I buy it I'll check to see if it can be done with the unix systems.
Will keep you up to date on what I find out.
Thanks Guys
rdel:)
I just signed up at titantv but under sat there is only listed dish, sky, and directtv, not fta. am I missing something ? hehe
IF you are in the US, pick OTA (antenna) then add the channels. There is no "FTA" list. You have to manually add the chanenls to the list by callsign :)
Big thanks to fellow forum member, motor is runnin!
Applying for the Whats up there area? Read this first!
