Help: Which Transponders Should I look at to determine optimal strength? | SatelliteGuys.US
120inna55
1,454
31
Athens, Texas, United States
I've asked this before, but never a clear answer...
Which transponders should I check for each satellite (I'm looking at 110, 119, & 61.5)?
Also, what is considered good signal strength with the new meter on the 622 (L409). I'm getting 44, 55, and 52 respectively.
Thanks.
Thanks.
I cant remember off the top of my head for 110/119(dont have 61.5 here), but its usually one of them from 10-13. Find the highest in that range and peak with it.
From what I used to have on my SS meter, Id say 50's were 90's and 60's were +100's.
New - add tv's with own equipment
How does one set up timer 14 days in advance on 622?
