Help: UNsuccessful dish hookup to Hopper | SatelliteGuys.US
DennisTheSatellite
23
2
:confused: PLEASE HELP !!
[FONT=&amp]I installed the Dish 1000.2 DPP Twin LNBF (Eastern arc) with one cable only.[/FONT]
[FONT=&amp]My Hopper keeps looking to Sat #3 but it has no signal.[/FONT]
[FONT=&amp]MY SETUP STEPS:[/FONT]
[FONT=&amp]1) I connected the one and only cable to LNBF port #1.[/FONT]
[FONT=&amp]2) Successfully aimed left lnb to 72 and right to 61.5 (good signal for each)[/FONT]
[FONT=&amp]2) Took cable completely off Hopper and ran ChkSW.[/FONT]
[FONT=&amp]3) Connected cable from LNBF into "Node Sat" #1.[/FONT]
[FONT=&amp]4) Connected "Node Host" out to Hopper.[/FONT]
[FONT=&amp]5) Ran CheckSW. [/FONT]
[FONT=&amp]RESULTS:[/FONT]
[FONT=&amp]"System Status": 72 has red bar, 61.5 field has no color[/FONT]
[FONT=&amp]Hopper's "Point Dish" shows 3 Sats. And it sometimes assigns a station to Sat 3# with the error message "no signal".[/FONT]
[FONT=&amp]I also ran a CheckSW >before< attaching the Node – same results[/FONT]
[FONT=&amp]Thank you, thank you for your help. :hatsoff:[/FONT]
External HD - using different receivers on the same account?
96 Hopper Timer Limit Removed
