Help understanding Lyngsat | SatelliteGuys.US
706Tom
69
North Georgia
On 101 degrees W there is a listing for Miami mux on DVB S2. Lyngsta says it is SD/encrypted. Does this mean it is available for S2 reception?
No it does not, just cause it says S2 does not necessarily mean HD. Lyngsat can be confusing sometimes.
DVBS2 is a transmission standard...that is all. All muxes can have a mixture of standard definition and high definition as well as having both encrypted and clear channels. So yes, if you have a receiver capable of handing the S2 standard your receiver will correctly present the channels that are in the mux and will probably have the $ symbol in front of the channel name to indicate that the channels are encrypted.
What does it cost to broadcast to satellites?
Elevation and/or declination on a WS9036
