Help! Setting up HD | SatelliteGuys.US
Help! Setting up HD
  • Thread starter Thread starter rxrod
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
rxrod
I have a Mitsubishi SR-HD400 HDTV Receiver. After installing multidish I received excellent signals on A, B ,& C. The problem is the diect tv Channel guide does not display. I called Direct TV & they said it needs to dial out to get the info. Is this right? If so is it an 800# it is dialing. It seems to dial out (I know this because my phone displays "extension in use") After a while I click in with the phone & their is a busy signal. I do have vonage which you have to dial 1+ area code for any number you dial. If it is trying a local number (I did insert my zip code at setup) maybe that's why it's not working. I am at a loss. Please help!
RGP port
Dish Customer thinking of switching..
