help me with multiple multiswitch question please!!!! | SatelliteGuys.US
blkbone33
19
I NEED HELP PLEASE!!!
i have a 3-lnb D** dish run thru a Zinwell 6x8 multiswitch on the roof. because of the poor previous calbe instal i had to drill into the house for each line of sat. my question is can i connect another multiswitch to one of the sat lines inside of the house in order to connect a few more tv's? i dont know if multiple multiswitches will work or not. if you have any advice please help me. i need to get my kids rooms taken care of, but i really dont want to drill into the house anymore!
i appreciate any help you can give.
i do believe the 6x8s are all cascadable so the answer is yes. but you would have to use four of your existing lines to feed the 2nd switch, so you would end up with 12 outputs (usable)
103 network 14 or 15
4x8 multiswitch
