Help! I emptied out my Hopper 3, including PTAT recordings, but DVR is still 16% full! | SatelliteGuys.US
The Hopper has recordings that are downloaded by Dish that take up room. The operating system is also there. The hard drive is 2TB so I wouldn't worry about it.
Also, did you empty your trash?
I recently turned PTAT off on one of my Hoppers and deleted all the PTAT shows that had been recorded and then emptied the trash. It took a few days before all the newly available hard disk space finally showed up in the usage percentage.
The movies (recordings) download by DISH & the operating system do NOT use any of your user space on the internal drive.
Reactions: pattykay
PTAT will take up until the amount of time you have them saved for to expire to be removed. You can delete a PTAT program and then go back into the search, and find that same program to view afterwards.
Reactions: pattykay
Sorry for the late response. Yes, I did empty my trash. But I assume with you guys' responses that you already explained why this happened?
Venting.... Sometimes Dish is Frustrating
Local Channel Reception Range
