Help hooking up D10 to new TV | SatelliteGuys.US
Willis
118
I was hoping someone could help me with my new TV set up...
I have a D10-100 that I want to hook to a new Sony Wega,(Standard-Definition Digital TV Model: KD-32FS170) I also am currantly using a VCR/DVD combo.
The D10-100 doesn't have Component Video outputs but my VCR/DVD does. Should I just run everything throught the VCR/DVD using component OR use S video from the D10-100 to the TV and then component from VCR/DVD to TV?
Help?
Since connection quality can differ from device to device, I would try them both, and see which has the better picture (to _you_), as we could never tell you which will end up looking better to you on your particular setup.
Good luck.
A couple of quick DVR questions!
How many Dish Antennas are needed?
