Help! Cable nightmare | SatelliteGuys.US
o22iestar
I know this sounds totally mundane but for some reason I've lost cable and can't get it back onto normal tv. The only options are line 1, line 2, component or a v.fuzzy screen - all cable channels apparently. I've been trying for an hour and can't seem to get the right combination or switch it back. Please help!
Do you have a cable box or no? if you havea cable box when your on the Snowy screen make sure your on Channel 3, so the box will show up. If you dont have a box and you still get a snowy screen Check to ensure cables are plugged in and if so call your local cable provider for a service call.
DVR (thru Comcast) vs DvD Recorder
Does Dish Have More Outages Than DirecTV?
