Hello and a question... | SatelliteGuys.US
jvic
3
Hello,
This is my first post here and I was wondering if anyone had any ideas with my issue. I have an 811 receiver playing on a 4:3 Panasonic HD set. When viewing HD programs, the left and right sides of the picture are getting cut off (apparent when text is on the screen). I have the aspect ratio set to 16:9, and my TV is supposed to adjust for this. It looks to be the standard letterbox widescreen size, but maybe it's not? I also tried both 4:3 options and it yield the same result of the image getting cut off. Thanks for any ideas. I tried to do a search and couldn't come up with anything, so I apologize if it's a dumb question.
Thanks!
Jeff
jvic said:
Hello,
Thanks!
Jeff
Welcome! :welcome
Have you tried using the zoom keys on the remote? PgUp and PgDn, and the * key. Maybe you're zoomed in too much.
That is EXACTLY what the problem was, thank you very much! This looks like a great site, I will definitely be looking around some more.
superdish question
sw 64 switch
