Need an advice on a HDTV that would double as a computer monitor. Also I would like to have a picture in picture so I could see whats happening on TV while surfing the internet. Thanks for any advice.
Does anyone have an H20 hooked up to their PC? and if so, what connections did you use? Are there even any Vid cards with component inputs?
I use Hauppauge WinTV-PVR-150 MCE Kit which uses the S-Video cable from an H20. No reasonable component ones out there that I am aware of. Video is not bad on my Windows Media Center and I also sling the video to my Xbox 360's that are networked. Its not pure HD but I also have a FusionHDTV capture card that does do OTA HD capture on the Media Center.
My kids mainly use this configuration since it gets them off my main DVR's. They can flip between TV's, go to any room, watch a DVD or go to the Media Center. I also use the Media Center for pictures and music since the speed and navigation blows away the HR20. I also use this configuration during football season as I watch a second game on an older SD TV. I have a Slingbox connected to the H20 as well so this configuration gets a good workout.
Thanks. I pretty much have the exact set up as you. I also have the Hauppauge PVR150 but no MCE kit.
What is the difference between computer monitor and TV monitor? Stupid question but I would like to know.
Dell 2405W doesn't have HDCP support but works fine with HR20-700 using HDMI-DVI cable.
The big question is whether or not this card supports HDCP. I'm betting that it doesn't.There is new HDMI capture card on market. $300.
Intensity Tech Specs said:The HDMI standard sometimes includes copy protection encryption, such as commonly found on DVD players and some brands of set top boxes. When connected to these copy protected sources, the HDMI specification defines that Intensity cards cannot capture.
HDMI is not required for HDCP. All computer monitors that support HDCP are DVI.Its a great monitor with DVI input but the HR20's are pumping out HDCP compliancy now on the HDMI output so I have to use a component to VGA converter to use.
Limited time offer
