HDTV capable component video switch | SatelliteGuys.US
Thanks for your input. But after having purchased one brand that resulted in less than perfect signal, I sent it back and went with the highest rated one: Zektor HDS4.1. It is not cheap, but hopefully it will live up to its billing. Should arrive in a few days. Will let folks know how it works.
Had a JVC switcher a few years ago before upgrading to a set with multiple component inputs. It was a passive switcher, but worked fine for me. Bought it on ebay then sold it on ebay when no longer needed.
Received the Zektor HDS4.1 today. It is a wonderful unit! Works perfectly without any signal loss or cross-talk between inputs. And it is very easy to teach the unit to work with your existing remote(s). That said, with the simple touch switch buttons on the front panel, there is really no need to use a remote. Expensive at $259, but it is a quality unit--made in the USA.
Home Theater
TV System Defaults?
