HDTV + 811 + Anything else? | SatelliteGuys.US
Silver3783
23
I got an HDTV, and I'm upgrading to the 811 reciever. Is there any other satellite equipment needed (such as some new LNB?). I noticed some LNB's have HDTV logo's and some don't.
Assuming you sub to the HD Package from dish, all you need is a dish pointed at 110/119. If you qualify for the CBS-HD feed, you'll need a dish pointing at 61.5 or 148 also. The 811 only needs one RG6 cable.
As far as non-satellite equipment, if you want over-the-air (OTA) HD, you'll need a UHF/VHF antenna for the digital signal. How big of an antenna depends on your location. The antenna connects to the rear of the 811.
DVI to SVGA Connection
FCC Rejects Digital TV Broadcast Rule
