Hdmi | SatelliteGuys.US
Hdmi
HD#1
437
Los Angeles
I have a 50 inch Samsung DLP and just bought a Samsung Blu-Ray players what is the best HDMI cable that I can buy so I can get the best possible picture. Thanks
It doesn't matter much. The cheap ones work just as well- it's digital, not analog. Don't waste your money on Monster.
There might be a shoddily built HDMI cable that mechanically will fall apart, but I wouldn't worry about that. Check Amazon, Monoprice, NewEgg, etc.
Over short distances (15' or less) you probably will not find any differences between cables. Really long runs probably need to buy a quality cable. Note that does not mean super expensive.
XBox 360 Add-on On Vista PC
HDMI on HD DVD
