HDMI Switch Pink Picture | SatelliteGuys.US
fcspag
4
I bought a cheap HDMI switch off EBAY. The picture looks fine with my Blue Ray selected but when I select my H23 DVR the picture is pink and no sound. What kind of HDMI switch works with Directv?
I think the key word here is cheap! How long are the cable runs?
That shouldn't be too long. Have you tried switching cables?
I get this on a WD Live box when running through a (cheap) autoselecting HDMI switch. It's got to do with the switch borking the digital handshake. The switch I use has a remote for manual selection.. If I switch to the WD input from something else (automatically or maunally), I get a pink screen, but if I press that input number a second time, it renegotiates the connection and it works fine (only the WD Live box does it regardless of what port it's on, not the D* receiver or bluray). If your switch has a remote, try that. Also might try not powering on the D* receiver until after you've switched the switch.
Please help with a little info.
Where is the new DIRECTIVO?
