HDMI splitter | SatelliteGuys.US
HDMI splitter
Splitting an HDMI signal doesn't always work. You may need a switch instead.
The number of times you can split will depend to some extent on how long the cables are. But as raoul says, that isn't the biggest issue. There needs to be communication between the receiver and the various TVs and a passive splitter won't give you that. You need an active intelligent device (a switch for example) to connect between the receiver and the TVs; go to monoprice.com and look at what is available.
OP; also just in case you don't know; all 4 displays will be on the same program at the same time. you will need individual receivers to view independent programs
The CW
Any reason for HR21 getting very slow?
