HDMI Cable Quality | SatelliteGuys.US
HDMI Cable Quality
I have purchased Amazon Brand and some from Monoprice, they are cheap and work fine.
Maybe when used with Hopper 3 and 4K there could be problems.
Dan
It seems to me that the cable issue would be the integrity of the plug itself, right? The material of the conduit the signal travels through makes no difference, since we're dealing with a totally binary signal -- it's either on or off.
Not necessarily. Interference can still cause corruption of the data stream in a poorly designed cable.
I've had one of the cheap ones from Walmart be intermittent, it didn't work unless you wiggled it.
Home media mp4 fixed U307
Change 722 remote address?
