HDMI Cable Quality | SatelliteGuys.US
HDMI Cable Quality
knighthammer
SatelliteGuys Guru
149
I've read quite a few posts here at SatGuys about buying HDMI cables from Monoprice as opposed to some of the large electronics box stores or buying Monster Cables. Monoprice cables are as good as if not better, etc. My question is this... what is the difference in quality of the HDMI cables available at Monoprice? They may have several 6' HDMI cables at different prices. So is the 35.00 one better than the 10.00 one? How do you know which one you need?
Look at the cable length, size (AWG), and the cable rating, some are v1.3 compliant; also some have a ferrite core, some have gold tips and some have an attractive net jacket. And some of nearly all that together.
What does all of that mean to a guy who just wants to hook up his TV to a VIP622?
I would recommend getting a thinner cable, so long as you don't have a long run or interference. I have 2 I think I'll replace. Thick, heavy, outside netting. And they lean ever so slightly out of the socket, making me get up and replug them in every now and then. I suspect this won't be a problem with lighter cables.
Magnavox 32 HD odd problem
Sharp Aquos LCD - Gaming Blur
