HD7084 placement | SatelliteGuys.US
HD7084 placement
SMG
24
would it be feasable to place this antenna in the attic
EDIT:
on CEAs site, it says i am about 10 miles away from all the stations. wouldnt that big ol anttena be overkill?
couldnt i go for a Medium Directional Antenna like the winegard square shooter?
You should not need anything that big, unless there are some problems at your location. Post your antennaweb.org results here - don't forget to put in your address not just your zip code.
pbs
inexpenisve attic mount?
