HD Upgrade - So far so good | SatelliteGuys.US
ahope577
SatelliteGuys Guru
123
Somerset PA
Just had a HD upgrade done that went very smoothly figured I'd give some positive feedback. I had an installer from Seeworld satellite do the upgrade installed a 1000+ DPP44 switch & Vip622. Installer was very professional arrived ahead of schedule & was done in 1 & 1/2 hours he was a little concerned that with the 1000+ dish he was not able to get a good position to mount the support struts, the dish is well lagged though & he said is we have any problems he will be back out to fix it gave me his home phone number as well :up
So far I am enjoying the HD service PQ looks great & so far it has been very positive.
Thought I would post a positive result.
Let me know your thoughts on the 1000+ not having the support struts attached we had high winds yesterday & no problem with PQ or signal strength & no rain fade, installer was very happy with signal levels off all sats.
Also thanks to you guys for running such a great site :)
What are the signal strengths for each sat. and where are you located?
Henry
Henry
Located East of Pittsburgh PA. I'll check sat strength tonight & update then
Edit: 129 tp22 signal = 75
119 tp11 signal = 105
118 tp11 signal= 71
110 tp11 signal=97
Weather: Raining & overcast
HD programming only available?
Help adding another reciever
