hd settings | SatelliteGuys.US
hd settings
swizz977
so i got my hd today playin wit the settings on the hd reciever and wondering whats up when u put it on 19by9 on the reciever it puts some chanals in 4by3 wierd and should i keep native off and whats up with the 1080i and 720p should i just leave it on 1080i
Welcome.
Not all programs on an HD channel are HD nor are all HD programs16x9 aspect ratio.
I set mine like this for my 16x9 TV & projector (720p native panels); but you my fine better setups for your gear.
DirecTV HD
1080i output
Native off
16x9 TV
black bar pillars
(i think) normal or original display
(typed from memory as I am at work)
Once you get the HD settings good, invest in a new keyboard.
I think you're missing the x key and a couple next to m that look like this: , .
Joking asisde, you'll probably be best to leave native off and set it for 1080i or 720p depending on the quality of your set. My projector is designed for 720p, so I use that.
I agree, native off works best (for me anyway).
I started out having mine set at 720P, but have since changed it to 1080i to let my tv do the scaling. I am working under the assumption that my Panny has a better scaler than the HR
DirecTV called to Upgrade my 10-250..
PPV Refund
