can a HD VIP211K reciever for dishnetwork still work on a regular SD dish? and if so how, what satellites will it have to be on. not being used on a HD tv.
after check switch it says something about not having all the satellites and if i push save i will lose some channels, does this just mean i won't get HD channels? afraid to push save cause not sure it i can undo it after i hit it.
If it had been properly installed, it wouldn't be connected to an "SD dish".Did you buy the receiver and plug it in, or did a tech come to your home?
Do'h!If it had been properly installed, it wouldn't be connected to an "SD dish".
Limited time offer
