HD receiver question | SatelliteGuys.US
Rinker97
74
Hi all,
I'm moving to a new house and already have my new HDTV scheduled to be delivered. I was to get D* for it but wasn't sure where I should get the equipment from. Should I go to D* or another online retailer? Is there a difference? Will they all probably use the same installer?
Now on the equipment itself. Is one HD receiver better than another? Or I guess I should just say, what model of receiver should I be getting? Eventually I would like to get the HD DVR but with spending a load on the HDTV, then more for the speakers and receiver, and then spending $300 on the HD receiver, not to mention the house itself, it may have to wait a bit.
Thanks in advance
Rink
Welcome to Satelliteguys!! :welcome
I would highly recommend visiting Value Electronics to get your D* HD Receiver. Since you're a Satelliteguys member you will receive a 10% discount that all Satelliteguys members get. You can click on the link up top or click here:
www.valueelectronics.com
These guys will take care of you.
There isn't too much of a difference between the different HD receivers that I can see.
Questions regarding adding another dish and DVR/Tivo units......
Receiver buying assistance needed
