HD Only Pak? | SatelliteGuys.US
HD Only Pak?
Hfivo
31
Connecticut
My question is... If I switch to the HD only pack and also my locals and if all my locals are not in HD, will I still receive them? ie: my Fox network is not HD, but since it is a local will I receive it in SD? Also, if I add premiums, will I recieve the SD premium channels?
You can get the HD Only plus locals (which I have). And the SD channels will still be there.
Just be sure to understand that you cannot get your RSN or even the package with the HD only package. Not an issue for me but some see this as the major blocker to going to HD only
HD only Package question
