Today I notice that I am not getting SD version of
USA, FOOD, TBS, TLC, TWC,TRAV channels.
No. It includes SD counterparts. Don't know why they are missing however.It is the HD only package, ah, no sd channels!!
I have the dishHD (only) package and ALL of these SD channels are working fine.Today I notice that I am not getting SD version of
Press Menu-6-1-1 Check Switch Test to make sure your kit is working correctly and reload the EPG.
Talon Dancer
I seemed to have lost Bravo on SD. Anyone else?
I tried to reset the receiver, the switch checked out fine.
It seems not all the SD versions are available. For example DISNEY E , ABC Familyyes, but it is part of the dishhd package and was simulcast on SD, it appears to be gone now
Limited time offer
