HD Lineup Info Channel 77 | SatelliteGuys.US
Those channels are moving to MPEG 4 and the 99/103 satellites. You need to have an MPEG4-capable receiver and a slimline (ka/ku) dish to receive them. The slide should have the new channel numbers listed. If you can see them on the new channel numbers you're all set. If not, you need to upgrade your equipment.
Actually the channels in question have been on the MPEG4 satellites now for a number of months. This is the notification that the MPEG2 versions are going to be shut down soon (rumor is before the end of February).
Does the upgrade come with Beyonce? :D If it does I want!!!!!:up
:D:hungry:
Right, but just for the sake of simplification, saying they're moving is easier to understand :)
Number of series links/todo list and dvr and menu speed
Direct T.V. Question
