hd install question | SatelliteGuys.US
hd install question
carlosg
83
Curent directv customer thinking abouth buying the samsung hd receiver from directv and I already have a offair antenna will the installer install it for me or will I have to buy one from them to install it?
Is your off air antenna outside or inside? Is it already wired into your satellite system?
You can use your own off air antenna. Your installer may or may not run a seperate coax cable for that, but you can always ask. Worst case scenario is he would use a couple of diplexors and run your OTA signal and Satellite signals on the same coax inside to your HD receiver.
HR10-250 Picture Quality (SD)
hd locals
