Is there a limit to how many dvrs or hd receivers you can have in one house? I want to purchase two HR21's but not sure if they have a limit.
I have 4 HD DVR's. Once you have the DVR features you don't want to go back to a receiver that doesn't pause and rewind. DVR is adicting.
except for the play room as kids don't need DVR or HD.
We have 3 HD-DVRs and one SD-DVR.
My 8 y.o. uses his DVR all the time, and has for 3+ years...
If I had to pick a limit, I would say 6 receivers per 3 bedroom household. 1 in the living room, 1 in the master bedroom, 1 in each of the two other bedrooms, 1 in the family/game room (basement), and 1 in the play room (basement). Any more then that (unless you have a huge house) would be questionable.
My thought is if your going to have a reciver, may as well make it a DVR or HD DVR, except for the play room as kids don't need DVR or HD.
OK - that's acceptable.The kids get a DVR in the bedroom, just not the play room.
If you have ALL of your receivers hooked to a phone line, D* probably doesn't care how many boxes you have on your account, since they can pretty much (for the most part) be assured those boxes are in ONE house.
But if you do NOT have any on a phone line, then they probably start checking things out if you go over 4+.
No phone lines are needed on the HR2x units, I do have one on my HR10.
I think the only think a phone line does is communicate your PPV rentals.
If your account has more than 6 Receivers then all the receivers over 6 have to have a land line phone line on them, and that number has to be the same on your account. I did a Install a few weeks ago for 8 HD DVR's and there was an VIP/OOP Note on it about it. and the CSR pinged the receivers prior to activation and said they get pinged 2-3 times a month.
Also a FYI you only need 1 receiver hooked up to a phone line for PPV if IPV is active on non-phone boxes. So say your HD box has no phone but the one in your wifes kitchen does, when you order PPV on the HD box, the Kitchen one will send out billing.
Limited time offer
