Hbo G-1 | SatelliteGuys.US
Hbo G-1
truckracer
4,338
352
Charleston wv
My HBO Channel 112 is down to 50%
Channel 100-111 is 93%!!
Skew won't bring the 50 percent up.
Wonder what's wrong. bumping dish don't help
How's your signal levels on the above tp's?
Here in California with a 7 1/2 foot mesh dish and a 922, I'm getting:
100-111 Signal 100 Quality 81
112 Signal 100 Quality 77
There is not much difference in the two signals. I'm not sure what could be causing your problem.
that is odd that the one tp is down. I am showing 99% on ch 111 right now.
51 on ch 112.
I will have to get into that tomorrow. No pixelation on the 50% though.
HBO will stay locked down to around 36 quality.
Channel 111 is vertical polarization and 112 is horizontal polarization. Sounds like you may need to re-tweak you horizontal skew. Good luck.
Not by Yourself
what actuator do I need
