Looks like HBO/Cinemax VOD is now available in HD![]()
Cool. Now if they would add 3D like some of the cable channels are doing.
S~
S~
I'd love to see HBO add a 3D channel, or 3D versions of it's programming.
Thats fine, but not at the expense of other HD channels.
Look, they have capacity. Not adding at this point has nothing to do with what we want, it's what they see best. Don't see it as the 3 3D channels they have are keeping BBC and others off HD, because one has nothing to do with the other. Adding HBO 3D has zero effect on "insert channel" in HD here.
You guys here skew WAY WAY WAY higher than the average bear (Yogi bear reference). Most customers on Dish, Directv, etc, etc are not HD customers. Not yet anyway. Just because 85% here are HD, doesn't mean 85% of the country is.
A significant portion of television households in the USA are still SD, as in everything they own is SD. That's part one, then you have the next part where a lot of homes have one HD television but the other 2 or 3 or 4 are SD. Mixed households as it were. That's the case for every MSO.
An HD box costs a LOT more than a HD box. I get what you're saying, but there's a point when this stuff makes sense and a point where it doesn't. No question long term this is where every MSO will go there are financial realities that have to be considered.
Oh, and not sure where you got the 10 million from, but you are wrong...
From Satracer recently:
Limited time offer
