Have To Move The Roof Dish Antennas. | SatelliteGuys.US
Been There
4
2
Southeast Kansas
Must move the 1000.2 and Single antennas due to a tree blocking some of the satellites. When I installed these antennas in 2005, I knew one day I would have signal problems as the tree has grown. So, I'm going to install two metal poles in the yard that has clear view to the western arc satellites. I need to know what size pipe I need.
I have several 6 ft. 1-5/8" outside diameter pipe that I can use. In my search for Dish mounting pipes, nothing can be found on what size ground pole that is required to mount the 1000.2 slimline dish. I'm going to use the Dish 500 with the single pro LNB that I have on the roof now, and I'm sure it also requires the same size ground pole.
I also ordered a Dish 1000.2 Western Arc Hybird slimline with Hybird LNBF with solo hub. Replacing the one on the roof now.
Dish hit with 469 million verdict
New Hopper Install Questions
