Have 1000.2, looking to add Dish HDTV. Options? | SatelliteGuys.US
baronpilot
5
I have a 1000.2 dish with a dp34 switch. I receive 110, 119 and 129. I'm only using two outputs right now, living rm and bedroom. Single cable connection to each room. Bedroom has a 311 receiver, Plain old TV (POTV)
Living room has 510 DVR for Dish, Zenith HD-SAT520 HDTV OTA receiver (DirectV, but only used or OTA) with outside antenna. TV is a Sony KV36XBR400 with component HDTV inputs but NO HDMI inputs.
I get all the major networks in HD OTA on the Zenith, and am happy with that. For DVR and non-broadcast I use Dish. I'm satisfied with Standard Definition on the DVR function, for now anyway. I know I will have HDTV DVR someday, but figure the longer I wait the better my price/performance ratio will be.
My Frustration is Football on ESPN, etc that looks bad on Dish. I'm spoiled by the Free HDTV OTA. I'm trying to avoid any new 2 year contract with Dish since I've found they treat me SOOO much better when they know I can cancell my service at any time.
Finally, my question. What should I do to get ESPN and other dish shows in HD? Add a Dish HDTV reciever that I pick up used to get Dish HDTV? I was looking at a Dish 811. It should probably get HDTV OTA, and replace the Zenith reciever. Then I would keep the 510 DVR for DVR function. I have two 1080i component inputs on the Sony XBR.
Will I need to run another cable from the Dish to the living room?
Clearly I'm cheap, but appreciate a good quality system and willing to deal with it not being leading edge.
Thanks for your comments.
The 811 will no longer work for Dish HD, you must have a VIP receiver. 211,411, 222,622,612 or 722. The 1000.2 is already setup for receiving HD. You will just need a new VIP series HD receiver. It is only 10.00 extra a month to receive the HD versions of any channels you already subscribe too. Whether it is better to lease an HD receiver from and extend your contact or buy new is up to you. I prefer to buy, don't like leasing anything.
"HD: normal" or "stretch" on Dish remote?
NBA League Pass HD
