Has anyone been brave enough to open up their Visionsat iv200 PVR? | SatelliteGuys.US
rjc3895
390
I love the Visionsat 200. I don't like the fact that the usb port is on the front.
I was wondering if anyone has peeked inside their box to see how the usb port is connected to the mainboard. If there is a usb socket on the mainboard, then it would be a fairly simple task to make a small opening on the back of the box and, using a usb internal cable, run the usb port out the back of the receiver. Of course this would void any warranty, but at least I could close the front door :)
I have the Visionsat 200. I do not like the USB port location either. Mainly the fact that you had to open the little door to access it. What I did was neatly cut a hole in the door big enough to fit the USB cable through. I was not brave enough to open the case for fear of damaging the unit.
I also have the GeoSATPro DVR-1100c which has the USB port in the rear. The Visionsat 200 is easier to access if you do a lot of swapping the cable back and forth between a computer like I do.
been there, seen that ...
Having the connector behind a front-located door is silly, that's for sure.
But, the general operation of the unit is great, so I overlook that one lapse of sensibility. ;)
And, after a year, I no longer really care where the connector is located.
edit: I made a suggestion in the review thread for solving the problem; scroll down to post #33.
My buddy emailed me photos. See attached pictures below.
I'm pretty sure I also took off the lid and looked for myself. :)
Thanks Anole.
I was looking for that post but could not find it. My speed reading skills suck:)
Cannot get White Springs on new system
more Scientific Calculator than even your Kids will need!
