Harmony Remote and HR24 Question.. | SatelliteGuys.US
RedWings
841
Leesburg, VA
I am controlling my HR24-500 with my Harmony 890. When I hold down the FFWD button, it takes a long time to skip to the next tick mark and then to the end of the program. It works a lot better with the stock remote.
Any idea what setting I need to change?
Maybe I am just misinterpreting your words.....Don't hold down the FFWD button on the Harmony. Each time you push it increases the speed of FFWD up to 4X. As Bob said, in FFWD mode selecting the skip forward or back key will take you one tick forward or backward.
If that is not the issue you are having. You can learn the IR signal of FFWD or do manual adjustments of the IR signal. The Harmony software gives you lots of options on tweaking the signal.
Ethernet Bridge?
Account Stacking V.S. Vacation Residence
