Harmony One used, is there a way to control HR20-700 from other room? | SatelliteGuys.US
engdork
6
Denver, Colorado
Harmony One is use how can I control receiver from other room?
I have an HR20-700 in our big living room that I run with a Harmony One (IR) remote. I would like to run another TV in the room below from the HR20. What are my options (if any) of having a remote that can control the HR20 from the room below. Since the Harmony One is an IR remote the HR20 has to be set on IR so I can't use an RF remote, right? If I change the HR20 to use an RF remote then the Harmony One won't work. I need the Harmony One as the wife can't operate the home theater system without it. Do I have any options other than switching the HR20 from IR to RF to IR depending on what remote I want to control the receiver?
Thanks for the help in advance.
:confused:
You certainly can use your Harmony in an adjacent room, however, you need additional hardware. You need wireless IR repeaters. Not overly expensive if I remember correctly ($100-150)
This should work, or something like it.
[ame=http://www.amazon.com/Startech-com-Wireless-Infrared-Extender-IREXT/dp/B000NPLHTU/ref=sr_1_79?ie=UTF8&s=electronics&qid=1243365885&sr=1-79]Amazon.com: Startech.com Wireless Infrared Remote Extender (IREXT): Electronics[/ame]
Help! Can't get HD's on Input #1
swm ?
