Harmony 900 and 922; has any one got them to work together? Can there be harmony with my new remote | SatelliteGuys.US
DVDDAD
790
15
Huntington, Long Island, NY
I can't get my new Harmony 900 to work with my 922. I'm new to Harmony, only had it a day. Before I spend a lot of time trying to get it to work, I was wondering if any of you had any luck getting them to work together and any ideas to help me to get mine to work. Any comments or suggestions would be greatly appreciated. Thank you.
The one thing you have to do to a 922 that's different from all other DISH recievers (AFAIK) is to turn on IR:
Go into the Setup menu -> Remote. Click the IR button and switch it to "Enable".
Add the 922 to your Harmony profile. Everything will work except for the Yellow and Blue buttons. (An early software update broke them and they haven't bothered to fix it.)
Does anyone know if there is a way to teach the yellow and blue buttons? I've tried, but I don't think there is a way to put the Dish remote in IR mode.
Tale of two 612's
922: Dozens of Reboots, Weird Behavior - Problem Solved!!!!
