Then what about this thread that tells how to set it:afulkerson said:The HR10-250 does not have a 30 sec skip forward. The remote might say it has but have not seen it on the regurlar remote that comes with the HR10-250...
dcwebman said:Then what about this thread that tells how to set it:
http://www.satelliteguys.us/showthread.php?t=35383&page=2
If it can be set, then it seems like I should be able to set it on the Harmony remote too, especially since there's a setting there for it.
Did you just select the 30 second option from the Harmony website dropdown list box or did you need to learn it from the original remote?afulkerson said:I then reprogramed one of my harmony 885 remote keys to have the 30 second skip assigned to that key and now the harmony does a 30 second when I press that key.
dcwebman said:Did you just select the 30 second option from the Harmony website dropdown list box or did you need to learn it from the original remote?
Limited time offer
