Hardware for two 622s | SatelliteGuys.US
oldbob
42
4
In April, I'll be upgrading a 921 to a 622. I'm also planning on purchasing another 622 since Dish won't lease two of these boxes to the same guy. I have two Dish 500s: one with DP Twin , the other with a DP Dual, and I have a DP-34 switch.
Will this be adequate to handle two 622s? If not, what do I need? I will be using each 622 in a Single TV mode ... if that matters. I currently have the 921 and a 501.
Note that you'll have to retire the 501 - or add another switch.
Depending on how many birds the 501 needs, it can be either a DP21 (2 birds) or a DP34 (3 birds).
Am I paranoid or is this possible.
942/622 cable HD install question
