hard drive replacement | SatelliteGuys.US
candless
2
Hi,
Is there anyway to replace a 625's hard drive? My unit's warranty is up (I own the unit) and I have several 120gb's lying around...
Thanks,
Eric
Look at the dishmod group on the Yahoo groups http:\\groups.yahoo.com\group\dishmod.
I believe as long as you use a HDD that is in the "approved" list, the 625 will automatically format and use it. Dish receivers have a database of acceptable HDD's built in.
Tweak 1000.2
Using Components for 622
