navychop said:There is the ViP722K, which has a different remote and may one day have a different UI. It has a slot for two OTA tuners, which you pay extra for. But it does not seem to be as stable as the standard ViP722.
There is also the ViP922, which, to be charitable, is a work in progress. I daresay you don't want one. Maybe in a few months, when they get the features working well.
Most, but not all, good deals go to new customers.
3 years. I didn't realize it had been out that long. Time flies.
Stay with your 722. The K model is very unstable. Every 6 months we have to replace ours.
My 722K has been faultless for over a year. If you are replacing that often, their must be a home electrical or over heating factor involved. Is your unit WELL ventilated and away from other equipment?
It is in a cabinet. Do you think i should move it out of there? No other equipment in there
Which receiver has 2 HD outputs? I have the 622 and the 2nd output is only SD, which I would like to be HD.I'm sure there are higher-end with features the VIP722 doesn't have, but if the VIP722 works and you're not needing different features (HD on second TV for example), why ponder an upgrade? I also have a 3 year old VIP722, and even after being off for 6 months with Dish Pause, it's still working great. And for the larger HD, with the USB option you can add pretty much any sized HD you'd like, which is nice!
Anyway, just curious.
Sam
There are no receivers with two INDEPENDENT HD outputs. All HD receivers have HDMI and compoment outs, but the two TVs would be watching the same thing.Which receiver has 2 HD outputs? I have the 622 and the 2nd output is only SD, which I would like to be HD.
YES, that's your problem, get it out of there, or get a small fan and always keep the cabinet door partially open. You've been cookin' them.![]()
Limited time offer
