Had a customer today that shows h366 downloaded this morning. Have no idea any of any changes though.
I've noticed that too, at least on my J3.Hopefully it fixes blackouts issues.
I'm having MoCA issues at my two Joey 4s. Everything is working good for several hours and then all of a sudden, at both J4s I get the four red MoCA bars. Then at the Joeys I also start getting the black screen issues and when I select the PTAT folder I get a blinking screen. It blinks between the recordings and the upper & lower select menus. A Hopper 3 pull the cord reboot clears up the issues. I'm on H365 and hope H366 fixes these problems.I've noticed that too, at least on my J3.
How will you prevent the forced upgrade?can't wait for H369, I will never upgrade from that
…Goose drank wine,can't wait for H369, I will never upgrade from that
I'm just shitposting about the number, don't mind me lolHow will you prevent the forced upgrade?
Yep, just found out I got H366 this morning. It took forever for me to get H365, then H366 got pushed out quickly.I just checked and found out I have 366, usually don't get updates right away but lately they've been coming in more often and more of the latest update. It took eons before I got 345 but since then it's been updating quite often. I have a H3 and a wireless Joey w/Access Point. I haven't checked the WJ.
Finally got H366 on it's own without doing a manual forced updated at 4AM Pacific Time on November 12, 2023 on a Hopper 3 with Hopper Plus with P12407 and noticed 4 issues:
3) On both H365 and H366 and possibly earlier - there are some folders automatically created by the show when there are multiple episodes for that title that when you select the folder after selecting Managed recordings, it would think it is 0 recordings so while one can select the EHDD but the transfer button will not be available because it shows 0 recordings. If I first went into the folder and then select Managed Recordings and then selected the individual or all recordings, then it would show the correct amount of recordings and the transfer would work.
Limited time offer
