H2x / HR2x Software Release 05D2 / 45D2 6/18/12 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,054
456
Central Michigan
Receivers included in this release:
HR20-700 • HR20-100
HR21-100 • HR21-200 • HR21-700 • HR21Pro
HR22-100 • HR23-700
HR24-100 • HR24-200 • HR24-500
R22-200 • R22-100
H21-100 • H21-200 • H23-600
H24-100 • H24-200 • H24-700
H25-100 • H25-500 • H25-700
Release Date: May 17, 2012
0x45CD - H21/23
0x05CD - All other receivers listed above
New features
None
Updated
Stability fixes
Under the Hood
Release Date: June 18, 2012
0x45D2 - H21/23
0x5D2 - H24/100, H24/200, H25/700, HR20, HR21, HR24/100, HR24/500
0x5D3 - HR24/200
0x59D - H25/100, H25/500
0x5CD - H24-700
Updated
Stability fixes
Resolution issue
Previous April Updates:
Minor UI updates
Game Lounge
Trick Play
Stability fixes
Under the Hood
PREV key in PIG
Minor YouTube/Pandora updates
Minor Playlist updates
Channel banner
Closed Captioning
This is weird. You show a release date for 0x5CD as 5/17, yet I've had it on my 3 HR24-500s since 5/5. And no, I'm not on CE's.
All that aside.
Ox5CD was a big improvement over 0x59E when it first got on my boxes. The two I have sole control of received the update and operated flawlessly from that point. My son's HR24-500 got the update and lost all recordings and all todo items. He was not a happy camper!
Since then, this update has started to show it problems, and unfortunately that seems to be the case with all these SW updates. Start out good, then degrade. Nearly a sure sign of memory leaks imo.
Now my 3 HR24-500s do this:
1. Video/Audio glitches on nearly any channel at random times. Doesn't matter if it is live or a recorded event.
2. Remote response/ignoring - back again. If I use the remote in IR or RF doesn't matter, but if I control the same box with the iPad, it never ignores or is slow to respond.
Overall speed is slightly slower than when I got the update, but still perfectly acceptable.
All that aside.
. You probably meant 5CB update on 5/5 as that is the SW Version number I'm seeing, so I'm guessing this 5CD update is to fix YouTube issues?
2nd Rcvr for 2 tv's in same room
Will receiver at new house instantly?
