H25 HDMI PORT | SatelliteGuys.US
H25 HDMI PORT
Danny001
303
13
Bangor, ME
Took my h25 tailgating, in a hurry to pack up to go to the game and just wrapped the card aroubd the receiver leaving it plugged into the back. Put it in a tote with rest of cables and tools and supplies, when i got home discovered the port snapped off from the inside..
Is there a way to convert RCA to component or HDMI.. im currently watching through RCA and its actually very watchable, best SD ive ever seen actually.
it shoulls work with the 10 pin to component or composite, whichever you need for your tv
There are converters available
You'll need to call Directv and get a new receiver.
No converter will get you any better picture than you have from RCA (composite ) outputs if the 10 pin and HDMI connectors are broken
Doctor j
Reactions: ryanogorman
There is a 10 pin component video cable that will allow component video on the H25.
Not the best solution, but it will solve your issue.
I had a few customers break off the connector like you did and wanted me to replace the receiver for then for free. Couldn't do that, but this did solve the issue.
With a tailgater setup you will not notice the difference between HDMI.
Look on the back of the H25, looks like an S Video cable.
You should be able to get them from eBay or your local dealer.
As a dealer the cables are given to us for Free as needed.
If you can't find one, send me a PM and I'll send one for $5 which covers my shipping.
Is my Genie starting to fail?
Multi receivers in 1 room- remote settings
