H25-700 with Standard Non-HD Dish | SatelliteGuys.US
nmoline
35
Indianapolis
I have an H25-700 receiver that I use at a different location on occasion. However, that location only has a standard dish (non-HD). Before I upgraded all the equipment everything worked fine. When I try to plug in the H25-700 HD receiver it does not work. Is there something I need to do differently to access my regular non-hd programming on this receiver using a standard dish or are the two not compatible?
Thanks!
The H25 will only work with a swm type lnb. That's the kind with only one output. A swm setup also needs a power inserter.
Actually you could use an older Phase III dish and a swm lnb, but it's not the best arrangement. The Slimline dish and swm lnb is the way to go.
SpikeTV not lining up with the guide times?
2nd Receiver on Different Antenna & Location?
