H24 + HR24 Receivers and wifi | SatelliteGuys.US
eastof111
68
Currently have two receivers, H24 and HR24. Also Cisco Valet Plus M20 router and two Vizio TVs with wifi.
1 - Can I add a Cisco or Netgear wifi adapter to each receiver to access the internet?
2 - Will each receiver be able to see and record/play off each other via wifi?
3 - Will my PC have access to the HR24 DVR?
or
Do I have to go with DTV to setup and use their products to accomplish this, i.e. HomeTV?
or
You can either go with running cat5 to both (not completely sure how it works) or go simple and go with the deca system. I would recommend deca
i use deca and was having to reset/ attach cable, blah blah blah and was becoming to much so i ordered the Directv Cinema Wireless box ($30) and took 5 mins to hookup and setup and all is MUCH better!
Bundling (also posted on Dish forum)
AM21N Signal Feed
